v4.0.0.39 - stable
v4.0.0.39 - stable
Version 4.0.0.39 is out!
What's New?
* a rebuild was needed caused by an unattended change in the latest UI lib I am using. That's what the .39 is for!
What's New?
- Some FTE sanity checks added
- Explorer Window scrolling optimized (when meta data column are shown)
- Other smaller bug-fixes
- stable
Re: v4.0.0.39 - stable
A new v4.0.1.0-beta is available (so "Check for Updates...") which beside a new UI Lib also fixes the scrolling issue (jumping back when sorted to the last focused node)...
v4.0.1.0-beta will not start. Also Proppfrexx Tagger.
Same problem as atlantic. Version v4.0.1.0-beta will not start. Back to v4.0.0.39 and working again.
Have you the .Net Framework v4.5.2 installed? On what OS are you?
As other users do report, that it is working fine... so I am not sure, what is different on your machine?
A new v4.0.1.1-beta (so „Check for Updates…“) is available… please check this one...
This one is working.
Thx Bernd and happy hollidays
Hi Berend.
Working on Windows 7 64 bit. .Net Framework v4.5.2 is installed. The new version v4.0.1.1-beta is working on my system.
/Willem
/Willem
oki - perfect.
