Installer "vs" proppfrexx time.exe
Adger
Post by Adger »
Running the updater of the most recent version (3.0.11.0) while running "proppfrexx time.exe" ("pfoatime") the installer halts and offers "retry", "ignore", and "cancel".
I quit pfoatime and choose "retry" and waited for a decent amount of time (about 5 minutes) but nothing happened. Tried "retry" again, no awail. Resolved to "ignore" with the same result. I finally choose "cancel", which aborted the install.
After this PFOA refused to start alltogether. Made sure pfoatime wasn't running and manually extracted the zip and overwrote the installation directory. After that PFOA started as expected, but had messed up settings for the routing (sound I/O ports) but that was a very minor issue.
Re: Installer "vs" proppfrexx time.exe
That's really strange, I just tested that here again and the 'Retry' works as expected (after I closed 'ProppFrexx ONAIR Time.exe').
What version of the 'ProppFrexx Updater.exe' are you having on your system?
Make a right-click on the 'ProppFrexx Updater.exe' in your ProppFrexx installation folder and select 'Properties' and go to the 'Details' tab.
it should report verison 3.0.2.0 for the 'ProppFrexx Updater.exe'.
I'll double check this!
Adger
Post by Adger »
Right now its version 3.0.2.0, but that's after overwriting the installation directory. I can't tell wether or not this version was installed during the last overwrite. I will keep an eye on this.
Adger
Post by Adger »
Tried this with the latest .1 update. Had pfoatime intentionally running while updating. Updater stalled, retry-ignore-cancel. Quit pfoatime, clicked retry. Installer froze with "unpacking...". Forced it to quit after 15 minutes and maually extracted the zip-content into install-dir. Guess installation now contains a lot of obsolete garbage...
Adger
Post by Adger »
...oh, and since that last update windows is complaining that "ProppFrexx Time.exe is no valid Win32 application" and therefore pfoatime would not launch (which I guess is fair: if I was an operating system I would refuse to launch software of zero bytes length, too.)
I have provided a modified version of the Updater.
Please download the following file: http://www.proppfrexx.radio42.com/downl ... pdater.zip
Then unzip this file to your ProppFrexx installation folder.
Do this before you perform the next "Check for Update...".
The modified version will now contain an extra step (prior to the actual unzipping of the update file) which validates any open application using any of the target folders files, giving you a warning in an extra dialog to close such applications.
This should hopefully resolve your issue.
Adger
Post by Adger »
I installed that updater some time ago (before the 11.2 update, I guess) and this time when updating to 11.3 I left pfoatime running intentionally. The dialog you mentioned never showed up and the installer once again failed.
Yes, I guess I found the issue...
Please redownload the above link: http://www.proppfrexx.radio42.com/downl ... pdater.zip
A new v3.0.11.4 is already available.
Adger
Post by Adger »
Works! Perfect. Thank you very much for resolving this!
