problem remote viewer
Sjeek
Post by Sjeek »
After updating proppfrexx to version 0.23 my remote viewer stopped working.
If I try to connect the server the following messages show op: Kan assembly Zyan Communication version =2.8.0.1 Culure=neutral, Public key token=65c3ab91440b7b86 niet vinden.
Is this a bug or a problem with the server?
Sjeek
Re: problem remote viewer
Post by Sjeek »
The viewer and proppfrexx runs on the same PC.
1 hour before i update proppfrexx it works perfect after the update it went wrong..
Maybe it is on the same PC, but not using the same folder to start it?
I just tried it here and all is working fine.
Or did maybe the update failed, because the RemoteViewer application was still running?
Sjeek
Post by Sjeek »
I think so far i can remember that viewer was running while update took place..
Is there a solution? try to update again?
You can do a full installation again (download). And then do the update again...
You won’t lose any data or config.
If your remote viewer runs on a different PC you need to update it’s files as well. Both needs to be on the same version!
