vu meter problem
mdegroot
vu meter problem
Post by mdegroot » 13 Feb 2019 21:58
One our dj's has a problem while voicetracking.
He has a mic, connected to an usb audio interface.
In the proppfrexx mixer, the mic input channel is set to mono, so left and right signal are the same.
But in the voicetrack window, on the vu meter, the left input is playing much louder than the right input.
The audio source in the voicetrack is the mic1 input.
He has the last version installed, and already tried removing and reinstalling proppfrexx completely but the problem remains the same.
It has already worked, he didn't change anything.
I took a few pictures.
Is there a sollution for this?
Re: vu meter problem
Post by radio42 » 13 Feb 2019 22:34
I am not sure, if this is really a ProppFrexx issue or bug?!
I assume, that you have connected a mono input signal to a stereo-input of your soundcard?!
I further assume, that you have defined 'Mono' in the mixer input configuration dialog.
But what have you set as the 'Processing' mode for the input mixer channel?
(i.e. make a right-click on the mixer channel and then select the 'Processing' sub-menu...)
mdegroot
Post by mdegroot » 13 Feb 2019 22:45
After changing the processing from stereo to standard mono, the problem was solved. I hadnt checked this. I thought that by setting the input to mono, it Should work.
But no bug, and problem solved.
Thx for the quick reply
Who is online
Users browsing this forum: No registered users and 11 guests
