What to do!
yourx
What to do!
Post by yourx » 09 Apr 2019 20:59
After the last update i have a lot of problems, like the DJ players stops, with loading grapics bulding, and after this the playlist stops with playing the next track. And this error popsup,
9-4-2019 20:50:56 [v4.0.5.23]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void dEdD(System.Object, System.Windows.Forms.ScrollEventArgs)
at ProppFrexx.DJPlayer.dEdD(Object , ScrollEventArgs )
at DevExpress.XtraEditors.ScrollBarBase.OnScroll(ScrollEventArgs e)
at DevExpress.XtraEditors.ScrollTouchBase.OnScrollCore(ScrollEventArgs e)
at DevExpress.XtraEditors.ScrollBarBase.DevExpress.XtraEditors.IScrollBar.ChangeValueBasedByState(ScrollBarState state)
at DevExpress.XtraEditors.ScrollBarBase.OnMouseDown(MouseEventArgs e)
at DevExpress.XtraEditors.ScrollTouchBase.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
at DevExpress.XtraEditors.ScrollBarBase.WndProc(Message& m)
********** End **********
Error Source: mscorlib.Boolean MoveNext()
at System.Collections.ArrayList.ArrayListEnumeratorSimple.MoveNext()
at System.Windows.Forms.Application.ExitInternal()
at System.Windows.Forms.Application.Exit(CancelEventArgs e)
at ProppFrexx.ProppFrexx_ONAIR.E0M9(Exception )
at ProppFrexx.ProppFrexx_ONAIR.n0MB(Object , ThreadExceptionEventArgs )
at w5.CM.Main(String[] args)
its for my 24/7 station a big problem :(
Re: What to do!
Post by radio42 » 09 Apr 2019 21:59
This looks very much like a general issue with the graphics device or driver.
Does the problem disappear when you go back to the Previous Version (which can be found in the related folder as a backup in the installation directory).
Also, what exact Edition are you using?
Can you also please mail me your file called „Error.log“ which can be found in the ProppFrexx AppUserData folder.
yourx
Re: What to do!
Post by yourx » 09 Apr 2019 22:38
I work with Professional Edition (Commercial)
error.log
26-2-2019 21:47:58 [v4.0.5.8]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void KDdt(System.Object, System.Windows.Forms.MouseEventArgs)
at ProppFrexx.DJPlayer.KDdt(Object , MouseEventArgs )
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.ButtonBase.OnMouseDown(MouseEventArgs mevent)
at ProppFrexx.UI.GlassButton.OnMouseDown(MouseEventArgs e)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at ProppFrexx.ProppFrexx_ONAIR.dK4W(Exception )
at ProppFrexx.ProppFrexx_ONAIR.TK4N(Exception )
at ProppFrexx.ProppFrexx_ONAIR.KK4h(Object , ThreadExceptionEventArgs )
at d8.Wd.Main(String[] args)
26-2-2019 21:48:50 [v4.0.5.8]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void eDZC(System.Object, System.ComponentModel.CancelEventArgs)
at ProppFrexx.DJPlayer.eDZC(Object , CancelEventArgs )
at ProppFrexx.DJPlayer.QDdr(Object , CancelEventArgs )
at DevExpress.XtraBars.PopupMenuBase.OnBeforePopup(CancelEventArgs e)
at DevExpress.XtraBars.PopupMenu.CreateSubControl(BarManager manager)
at DevExpress.XtraBars.PopupMenu.ShowPopupCore(BarManager manager, Point p, IPopup parentPopup)
at DevExpress.XtraBars.PopupMenu.ShowPopup(BarManager manager, Point p, PopupControl parentPopup)
at ProppFrexx.DJPlayer.fDd2(Object , MouseEventArgs )
at System.Windows.Forms.Control.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.LabelControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraEditors.LabelControl.WndProc(Message& msg)
at ProppFrexx.ProppFrexx_ONAIR.K0Mx(Exception )
9-4-2019 20:52:12 [v4.0.5.23]:********** Error/Exception Information **********
Error Message: Collection was modified; enumeration operation may not execute.
yourx
Re: What to do!
Post by yourx » 09 Apr 2019 22:42
and version 4.0.5.23
yourx
Re: What to do!
Post by yourx » 10 Apr 2019 09:26
For now i did yesterday a driver update graphics device and boost(overclock) my graphics card.
Proppfrexx is running without stopping after 12 hour, i'll keep you informed.
Re: What to do!
Post by radio42 » 10 Apr 2019 09:48
Very strange - can you clearly reproduce the issue? If yes, what are the exact steps to do so - as it seems, that I am not able to do so.
Have you tried to restart your machine? Maybe there was an unattended Windows Update happening, which needed a reboot?
Else, the exception is hard to explain to me, as I I cannot see any reason how this should happen.
But yes, let us keep an eye on this, if it happens again!
yourx
Re: What to do!
Post by yourx » 12 Apr 2019 23:05
ok this is the issue,
It starts after update to v4.0.5.19 - stable
1. DJ players stops, with loading grapics bulding, and after this the playlist stops.
2. I think your right! aboud unattended Windows Update happening ( it was coming up)
3. this is what i have don, update video driver and overclockt de video card a litle.
4. after this process the system was stable but after 20 hour thare was 1 loading graphic bulding problem.
5. after update v4.0.5.25 Proppfrexx runs stable no problems.
thanks for your attention Bernd.
Who is online
Users browsing this forum: No registered users and 6 guests
