Proppfrexx crashes
- Soulmaster
Proppfrexx crashes
Suddenly proppfrexx is crashing after a few minutes.. really don't know why this is suddenly happening
Re: Proppfrexx crashes
If ProppFrexx is crashing because of an internal error, there MUST be an entry in the file called "Error.log" contained in the ProppFrexx AppDataUser folder. Please provide that information here, if available.
If ProppFrexx is crashing because of an error in the system, e.g. a buggy device driver, sound card error or a like a related log entry in made in the Windows Event log. Please provide that information here, if available.
Without further info I can not help. Probably there was an unattended Window Update happening recently which caused the instability? E.g. the latest Windows Update 1903 is known to cause some trouble for example when you access your machine via RDP.
- Soulmaster
hmm can't find it in appDataUser. got 1 map Radio42 but there is no file called error.log
It is in: %appdata%/radio42/ProppFrexx ONAIR/4.0
The file is called "Error.log" - if there is not even such a file present, the 2nd explained option would apply and take a look to the Windows Event log!
- Soulmaster
got it !!
18-11-2018 13:31:22 [v4.0.5.1]:********** Error/Exception Information **********
Error Message: The type initializer for 'Un4seen.Bass.Bass' threw an exception.
Error Type: System.TypeInitializationException
Error Source: Bass.Net.Int32 BASS_GetVersion()
Inner Exception: Unable to load DLL 'bass.dll': Kan opgegeven module niet vinden. (Exception from HRESULT: 0x8007007E)
at Un4seen.Bass.Bass.BASS_GetVersion()
at ia.Aw.FEeA()
at ProppFrexx.ProppFrexx_ONAIR.QbzN(Object , EventArgs )
Error Message: Unable to load DLL 'bass.dll': Kan opgegeven module niet vinden. (Exception from HRESULT: 0x8007007E)
Error Type: System.DllNotFoundException
Error Source: Bass.Net.Boolean BASS_SetConfig(Un4seen.Bass.BASSConfig, Int32)
at Un4seen.Bass.Bass.BASS_SetConfig(BASSConfig option, Int32 newvalue)
at Un4seen.Bass.Bass.Aqc()
at Un4seen.Bass.Bass..cctor()
at ProppFrexx.ProppFrexx_ONAIR.yQbP(Exception )
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc(Message& m)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at DevExpress.XtraBars.Ribbon.RibbonForm.SetVisibleCore(Boolean value)
at QJ.xl.ib0g(String[] )
********** End **********
15-2-2019 16:49:47 [v4.0.5.8]:********** Error/Exception Information **********
Error Source: ProppFrexx ONAIR.Void SKZl()
at ProppFrexx.ProppFrexx_ONAIR.SKZl()
at ProppFrexx.ProppFrexx_ONAIR.dK4W(Exception )
at ProppFrexx.ProppFrexx_ONAIR.TK4N(Exception )
at ProppFrexx.ProppFrexx_ONAIR.KK4h(Object , ThreadExceptionEventArgs )
at d8.Wd.Main(String[] args)
As you can see, the last entry is from: 5-2-2019 16:49:47 [v4.0.5.8]
As such, it seems, that there is NO recent entry from yesterday or the day before. This means, that ProppFrexx did not crash because of a ProppFrexx error, but because of an unstable system.
As written already above, if ProppFrexx is crashing because of an error in the system, e.g. a buggy device driver, sound card error or a like a related log entry in made in the Windows Event log. Please provide that information here, if available.
Can you actually reproduce the error? I.e. if not, it might have been caused by an unattended update of the system?
Any News? Can I assume this issue solved and only be a temp issue?!
No feedback... as such, I assume, that the issue is solved.
