Unhandled Exception at Startup
szal77
Post by szal77 »
********** Error/Exception Information **********
Error Message: Cannot access a disposed object.
Object name: 'XtraScrollableControl'.
Error Type: System.ObjectDisposedException
Error Source: System.Windows.Forms.Void CreateHandle()
   at System.Windows.Forms.Control.CreateHandle()
   at System.Windows.Forms.Control.get_Handle()
   at System.Windows.Forms.Control.get_ShowKeyboardCues()
   at DevExpress.XtraEditors.LabelControl.get_HotkeyPrefixState()
   at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcSimpleTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth)
   at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode)
   at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(Boolean useHotkeyPrefix)
   at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextPoints()
   at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcContentRect(Rectangle bounds)
   at DevExpress.XtraEditors.LabelControl.LayoutChanged(Boolean isVisualUpdate)
   at DevExpress.XtraEditors.LabelControl.LayoutChanged()
   at DevExpress.XtraEditors.LabelControl.OnHandleCreated(EventArgs e)
   at System.Windows.Forms.Control.WmCreate(Message& m)
   at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
********** End **********
This is v3.0.11.19.
szal77
Re: Unhandled Exception at Startup
Post by szal77 »
The error seems to be version-independent; I rolled back to v3.0.11.12 and get the same exception message. Additionally, after I click the message away approx. 10 times (doesn’t matter whether clicking ‘Stop’ or ‘Continue’), I get another exception message (only once); when clicking that one away, PFOA just hangs on the splash screen saying ‘Please wait, creating players…’ ?
Error Source: ProppFrexx ONAIR.Void i(Boolean)
   at ProppFrexx.d5.i(Boolean A_0)
   at ProppFrexx.d5.r(Boolean A_0)
   at ProppFrexx.ax.f()
   at ProppFrexx.ax.j()
   at ProppFrexx.ax.g()
   at ProppFrexx.cx.ag(Object A_0, EventArgs A_1)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
szal77
Post by szal77 »
Sent to your public e-mail address.
THX I'll take a look!
The two exceptions you posted are different! The one in v3.0.11.12 was already fixed in v3.0.11.13 or above.
Can you please send me your "Error.log" file (contained in the ProppFrexx AppUserData folder) to take a look at - this might reveal some more details.
szal77
Post by szal77 »
Fixed by deleting the main .layout file. Now, among other things, all my mixer settings are gone… :'(
That is a bit strange, as the .layout file doesn't contain any mixer settings.
They are stored in the Default.mixer file!
szal77
Post by szal77 »
The mixer layout was still intact, but all the settings, like DSPs, equalizers, etc. I had to recreate.
Should now be solved in v3.0.11.20!
