Advertising & News
grebda
Advertising & News
Post by grebda »
I tried Advertising & News and wrote me this error:
********** Error/Exception Information **********
Error Message: Method not found: 'Void DevExpress.XtraEditors.MemoEdit.set_UseOptimizedRendering(Boolean)'.
Error Type: System.MissingMethodException
Error Source: ProppFrexx Advertising.Void a()
at ProppFrexx.ao.a()
at ProppFrexx.ao..ctor(e A_0)
at ProppFrexx.k.g()
at ProppFrexx.k.h(Object A_0, ItemClickEventArgs A_1)
at DevExpress.XtraBars.BarItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkClick()
at DevExpress.XtraBars.BarItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.BarItemLink.OnLinkActionCore(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg)
********** End **********
SORRY FOR MY VERY BAD ENGLISH !! :-( :-(
Re: Advertising & News
This is indeed a weird exception.
It can actually only come up, if a component library is infact missing on your System.
Can you please double-check, if the following file is present within your ProppFrexx Installation Folder:
- "DevExpress.XtraEditors.v13.1.dll"
When you right-click on this file and select 'Properties - Details', please check the following:
The product-version should be '13.1.5.13198' with a last modification date from the '17.07.2013'.
If this is not the case, something with the update must have go wrong...OR...you might have copied the files manually to a different directory and have forgotten to copy some of the 'DevExpress...' files...?
Any news?
Guess this can be closed?!
grebda
Post by grebda »
I was on vacation! So I could not respond, I put there DevExpress.XtraEditors.v13.1.dll from previous versions, and it's working! Thank you very much
