Update adrvertising library
I am running PF advertising to schedule some audio files.
Is it possible to add a control command to send to OnAir instance to reload the adv library ?
Otherwise I have to run pf to send this control command or run teamviewer to update from OnAir.
Re: Update adrvertising library
You mean from the advert manager to PF I assume...
Yes, I'll take a look at that.
The v3.0.13.27 the Advertising GUI now contains a 'Sync ONAIR' button.
When clicked it will trigger a reload of the Advert Lib within ProppFrexx ONAIR (Note: it might actually take up to 60 sec. to effectively start/trigger the reload within ONAIR).
