remote voicetracking password access
Bernd, the remote voice tracking tool is aboslutely brilliant, it works perfectly, it's a priceless tool I definitely love it
Is there a way to use it without having to enter password each time you download the files?
Thanks,
T.
Thanks,
T.
Re: remote voicetracking password access
No.
I guess this would violate all security standards
Why is this an issue? Just to must work
Just thinking about optimizing the workflow, it's a bit annoying to have to enter the password each time...
you first enter the password to download the playlist. if you did it once, why do you need to enter the password again each time you download a file from this playlist?
Anyway; its not a big deal, but as I tried it for the first time, it's been my feelling about this. I suppose there's another way: select first all the tracks you need for you voice tracks(only one passsword requested), but it seems more logical to go one VT after another, in a chronologic progression.
Thomas.
Thomas.
I'll take a look, if an option to 'keep' the password for the 'current session' might be possible....
v4.0.1.12 now contains a new 'Remember Me' checkbox...
