Editing Cartwall metadata
FYI, It might be not a bug, but I discovered an interesting thing. If I open an cartwall medialib to edit the tags, CPs, etc, when I finish with editing and I click on Save Metadata Tags, it wont save tags until I unload from the cartwall.
Regards, David
Regards, David
Re: Editing Cartwall metadata
Yes, that is indeed not a bug, as the loaded items still hold the files open unless they are unloaded. Not much to do about it. Except using playlist based media libs, where the meta data can be saved in the playlist file.
