Customize layout overlay player
How can I save the settings after customizing the layout of the overlay player?
After drag and drop with the column chooser (removing partner, campaign and options) they are visible again in the next hour.
Re: Customize layout overlay player
So after customizing the layout I need to close ProppFrexx and reopen it. Will try it directly.
I closed PF and reopened it, but the settings changed to default
You changed your answer I see; OK see it in a future update
Yes, but with each type of overlay (depending on Advert, Script etc.) I currently automatically re-enable/hide certain columns - so it will not work as you want it.
The column layout of the Overlay Player is currently not really persisted
I'll put this on the wish list...
