D&R airence cartwall LED
moogwill
Post by moogwill » 19 Apr 2017 08:30
Hi Bernd, Hi All,
Our airence now is quiet fully "Proppfrexx Ready" But I'm stuck on a detail regarding Cartwall Leds, I didn't had any trouble to set leds on the switch I used for specific purposes(associated to players states). It seems that with the cartwall things are more complicated, and I wasn't able to find any answer in the operation manual. no problem to set the action of the switch (wich starts the carts) but where to configure the Leds. I need to get the information for each switch (paused playing stop end to associate each running action to a state, and I can't find how).
Thanks.
T.
meisterpropper
Re: D&R airence cartwall LED
Post by meisterpropper » 19 Apr 2017 08:37
I think you should use EXEC_SEND_DRAIRENCE_SETLED ${cartid}|1 at General Settings => Events / Commands => Cartwall => OnAnyCart1Started
moogwill
Post by moogwill » 19 Apr 2017 09:13
thanks Meisterpropper, The ${cartid} macro was probably the missing link... (no clue where's that macro in the user manual) Will try that And keep you updated.
T.
moogwill
Post by moogwill » 19 Apr 2017 09:57
probably missed it, :-/
Thanks,
T.
Online
Post by radio42 » 19 Apr 2017 19:28
You might use for example the following events and commands:
OnCart1Play (general settings, Events/Commands):
EXEC_SEND_DRAIRLITE_SETLED ${cartid}|1
OnCart1Paused (general settings, Events/Commands):
EXEC_SEND_DRAIRLITE_SETLED ${cartid}|2
And for a cart switch (GPIO mapping):
CTRL_SWITCH.1 = 0 EXEC_SEND_DRAIRLITE_SETLED 1|2
Online
All macros are in the Appendix of the User Manual.
moogwill
Post by moogwill » 20 Apr 2017 11:36
meisterpropper wrote:
19 Apr 2017 08:37
I tried that, when using two carts at the same time, led's won't update correctly.
Bernd solution was the right one (once I realized it wasn't the Airlite commands).
I used a third color when cartwall change, it's nice & useful, informing you that a cart still wasn't played at this time.
One thing is still a problem, for exemple: you load a cartwall configuration on 12 Carts, The first twelve Leds are on (yellow for me), then you move to another cartwall combination, using only the first six carts that turns yellow again, then unfortunately the six other leds won't shut down, still showing last state (paused or changed)... still searching how to correct that.
Thanks for your help so far,
Thomas.
Online
Post by radio42 » 20 Apr 2017 21:54
For this you can use the 'OnCartwallChanged' even and first turn all LEDs off.
Use a value of 255 to affect all LEDs, e.g. like this:
EXEC_SEND_DRAIRLITE_SETLED 255|0
Hogeland
Post by Hogeland » 11 Dec 2018 15:48
Hi Moogwill,
Did you manage to let the cartplayer work with the Airence?
Somehow i can't get the reset of the led's done by the way Bernd suggests, tryed some other things to but with no results.
Can you please let me know if it works for you and how you did it?
Kind regards,
Henk
Online
Post by radio42 » 11 Dec 2018 17:01
Sorry, I just corrected the above. The ALL_LED number is 255! Ie. try the following:
If that doesn't work out, please contact your D&R dealer for help.
Who is online
Users browsing this forum: No registered users and 12 guests
