PF and Behringer soundcard issues
Bumperke
Post by Bumperke »
One of my fellow PF users is expriencing this perticular problem. What can be the problem?
Wil
Re: PF and Behringer soundcard issues
That looks like a mixer setup issue - e.g. the Mixer Channel to which is DJPlayer is routed is not created correctly.
The user should check and make sure, that all Mixer Output Channels are created and working correctly - especially the once being used by the DJ Players.
Note, that the user can test each mixer channel in the general settings - see the Test Tone button.
If needed you can check which Mixer Output Channel is being used in the 'Routing' section of the general settings.
Bumperke
Post by Bumperke »
Bumperke wrote: 09 Jun 2017 16:27
Bumperke wrote: 09 Jun 2017 16:26
radio42 wrote: 09 Jun 2017 16:09 That looks like a mixer setup issue - e.g. the Mixer Channel to which is DJPlayer is routed is not created correctly.
Th xs Bernd, there are, on the other hand a load of problems with this soundcard. What would be your advice purchasing a soundcard in a not professional matter? Something good, simple and on the other hand to to expensive? All these problems are ruining his free :roll: time,
There are a lot of good soundcards.
And I cannot nor will I do any specific hardware recommendations.
However, the soundcard should come with decent Windows 10 drivers.
meisterpropper
Post by meisterpropper »
I can recommand RME soundcards. They work very good, have a great implementation in ProppFrexx and run 24 hours a day. If want to combine soundcard and mixer use the D&R series. Airlite or Airence. Airence is a little bit more stable.
Bumperke
Post by Bumperke »
Thx people
