Change in library history behaviour?
I am noting that script lines are sometimes randomly being skipped. So I created a new script with just two lines: Random A-list, and Random E-list.
Upon testing the script, I get this:
It seems to be very random whether it does skip it or not. As you see, it tries the A-list line, then the E-list line, then the E-list line before it finally succeeding when doing the A-list line once again, without much indication why.
I've narrowed it down to what I believe to be the library history, as the issue does not happen with SuppressHistoryCheck alone but does with SuppressHistoryCheck and ForceLibraryHistoryCheck. For extra insurance, I also tried the script options SuppressGlobalHistoryCheck, SuppressAdditionalHistoryCheck, SuppressGlobalRestrictions and SuppressTrackRestrictions. Script "Max. History" is also set to 0 so it must be the library history. And indeed setting the library history to 0 fixes the issue.
The setup I have is:
UseLastTrackOnFinalFail does not have any effect in this case. It does not prevent the script lines from being skipped, though it shouldn't need to be in the first place.
This did not happen in v4.0.3.46 but does in v4.0.3.49 and .50. I do not have a copy of .47 and .48 to test.
Has the behaviour of library histories changed?
21/07/2017 13:24:31: Script Test started for : Test3
21/07/2017 13:24:31: Processing Script-Line 1 (Retries=160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: Script-Line 1 skipped: no track found 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: Script-Line 2 skipped: no track found 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: Cancelled Script at Line 1 (LineTries=0, Tries=0/160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: Cancelled Script at Line 1 (LineTries exceeded): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: GetNextTracks processed, 0 script result entries returned.
21/07/2017 13:24:31: Processing Script-Line 2 (Retries=160): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
21/07/2017 13:24:31: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Maggie Lindemann - Pretty-Girl, Cheat Codes remix.wav).
21/07/2017 13:24:31: Processing Script returned: Maggie Lindemann - Pretty girl (File=\\NAS\Audio\Music\Maggie Lindemann - Pretty-Girl, Cheat Codes remix.wav).
- A-list: 20 items; history: 15
- E-list: 400 items; history: 300
Re: Change in library history behaviour?
Thanks for the info! There was indeed a bug with the Library Histroy Check.
A new v4.0.3.53-update is already available!
I've been trying v4.0.3.54 and I'm still experiencing the issue unfortunately.
What exact issue? I guess this might now be a tagging (e.g. your Albums, Artists or Title tags are not set correctly) or another issue...
Please post the output of the above 'Test Script' feature to take a look at...
It's similar output to that posted originally. There's no information why the script lines are skipped, seemingly randomly. (I'll get a fresh output later again if you want.)
To what extent does library history read into TAGs? I can setup a new library later and make things as unique as possible, though I'm not getting any issue with global history, nor did I with library histories in v4.0.3.46.
Oh there is info in it - you just might not be able to get it yourself (e.g. 'no track found'). So please post your new script test result.
Two tests run after each other:
Performed with the options mentioned above, so it is suppressing global history etc.
25/07/2017 12:11:09: Script Test started for : Test3
25/07/2017 12:11:09: Processing Script-Line 1 (Retries=160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Louis Tomlinson and Bebe Rexha with Digital Farm Animals - Back To You.wav).
25/07/2017 12:11:09: Processing Script returned: Louis Tomlinson ft. Bebe Rexha & Digital Farm Animals - Back to you (File=\\NAS\Audio\Music\Louis Tomlinson and Bebe Rexha with Digital Farm Animals - Back To You.wav).
25/07/2017 12:11:09: Processing Script-Line 2 (Retries=160): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: Script-Line 2 skipped: no track found 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: Script-Line 1 skipped: no track found 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: Cancelled Script at Line 2 (LineTries=0, Tries=0/80): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: Cancelled Script at Line 2 (LineTries exceeded): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: GetNextTracks processed, 0 script result entries returned.
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Rudimental - Sun Comes Up ft James Arthur.wav).
25/07/2017 12:11:09: Processing Script returned: Rudimental ft. James Arthur - Sun comes up (File=\\NAS\Audio\Music\Rudimental - Sun Comes Up ft James Arthur.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17646.mp2).
25/07/2017 12:11:09: Processing Script returned: Union J - You got it all (File=\\NAS\Audio\Music\_IMPORTED_\SP17646.mp2).
25/07/2017 12:11:09: Cancelled Script at Line 1 (LineTries=0, Tries=0/160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: Cancelled Script at Line 1 (LineTries exceeded): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Rita Ora - Your Song.wav).
25/07/2017 12:11:09: Processing Script returned: Rita Ora - Your song (File=\\NAS\Audio\Music\Rita Ora - Your Song.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18731.mp2).
25/07/2017 12:11:09: Processing Script returned: Rita Ora - Radioactive (File=\\NAS\Audio\Music\_IMPORTED_\SP18731.mp2).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18798.mp2).
25/07/2017 12:11:09: Processing Script returned: Stooshe - Slip (File=\\NAS\Audio\Music\_IMPORTED_\SP18798.mp2).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17278.mp2).
25/07/2017 12:11:09: Processing Script returned: Lana del Rey - Summertime sadness (File=\\NAS\Audio\Music\_IMPORTED_\SP17278.mp2).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:11:09: Processing Script returned: Miley Cyrus - Malibu (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Calvin Harris ft Pharrell Williams, Katy Perry & Big Sean - Feels.wav).
25/07/2017 12:11:09: Processing Script returned: Calvin Harris ft. Pharrell Williams, Katy Perry & Big Sean - Feels (File=\\NAS\Audio\Music\Calvin Harris ft Pharrell Williams, Katy Perry & Big Sean - Feels.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:11:09: Processing Script returned: Little Mix ft. Stormzy - Power (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Major Lazer - Know No Better (ft Travis Scott).wav).
25/07/2017 12:11:09: Processing Script returned: Major Lazer ft. Travis Scott, Camila Cabello & Quavo - Know no better (File=\\NAS\Audio\Music\Major Lazer - Know No Better (ft Travis Scott).wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\David Guetta - 2U ft Justin Bieber.wav).
25/07/2017 12:11:09: Processing Script returned: David Guetta ft. Justin Bieber - 2U (File=\\NAS\Audio\Music\David Guetta - 2U ft Justin Bieber.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Liam Payne - Strip That Down ft Quavo.wav).
25/07/2017 12:11:09: Processing Script returned: Liam Payne ft Quavo - Strip that down (File=\\NAS\Audio\Music\Liam Payne - Strip That Down ft Quavo.wav).
25/07/2017 12:11:09: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17670.mp2).
25/07/2017 12:11:09: Processing Script returned: Taylor Swift - Blank space (File=\\NAS\Audio\Music\_IMPORTED_\SP17670.mp2).
25/07/2017 12:11:10: Processing Script-Line 1 (Retries=160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Louis Tomlinson and Bebe Rexha with Digital Farm Animals - Back To You.wav).
25/07/2017 12:11:10: Processing Script returned: Louis Tomlinson ft. Bebe Rexha & Digital Farm Animals - Back to you (File=\\NAS\Audio\Music\Louis Tomlinson and Bebe Rexha with Digital Farm Animals - Back To You.wav).
25/07/2017 12:11:10: Processing Script-Line 2 (Retries=160): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: Script-Line 2 skipped: no track found 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Rudimental - Sun Comes Up ft James Arthur.wav).
25/07/2017 12:11:10: Processing Script returned: Rudimental ft. James Arthur - Sun comes up (File=\\NAS\Audio\Music\Rudimental - Sun Comes Up ft James Arthur.wav).
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:11:10: Processing Script returned: Miley Cyrus - Malibu (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Shawn Mendes - Holding Me Back.wav).
25/07/2017 12:11:10: Processing Script returned: Shawn Mendes - There's nothing holdin' me back (File=\\NAS\Audio\Music\Shawn Mendes - Holding Me Back.wav).
25/07/2017 12:11:10: Script-Line 1 skipped: no track found 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: Cancelled Script at Line 2 (LineTries=0, Tries=0/80): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: Cancelled Script at Line 2 (LineTries exceeded): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:11:10: GetNextTracks processed, 0 script result entries returned.
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:11:10: Processing Script returned: Little Mix ft. Stormzy - Power (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:11:10: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17311.mp2).
25/07/2017 12:11:10: Processing Script returned: Jason Derulo ft. 2 Chainz - Talk dirty (File=\\NAS\Audio\Music\_IMPORTED_\SP17311.mp2).
25/07/2017 12:23:02: Script Test started for : Test3
25/07/2017 12:23:02: Processing Script-Line 1 (Retries=160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: Script-Line 1 skipped: no track found 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18762.mp2).
25/07/2017 12:23:02: Processing Script returned: Bruno Mars - When I was your man (File=\\NAS\Audio\Music\_IMPORTED_\SP18762.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\David Guetta - 2U ft Justin Bieber.wav).
25/07/2017 12:23:02: Processing Script returned: David Guetta ft. Justin Bieber - 2U (File=\\NAS\Audio\Music\David Guetta - 2U ft Justin Bieber.wav).
25/07/2017 12:23:02: Processing Script-Line 2 (Retries=160): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: Script-Line 2 skipped: no track found 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Camila Cabello - Crying In The Club.wav).
25/07/2017 12:23:02: Processing Script returned: Camila Cabello - Crying in the club (File=\\NAS\Audio\Music\Camila Cabello - Crying In The Club.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17215.mp2).
25/07/2017 12:23:02: Processing Script returned: Jason Derulo - The other side (File=\\NAS\Audio\Music\_IMPORTED_\SP17215.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Major Lazer - Know No Better (ft Travis Scott).wav).
25/07/2017 12:23:02: Processing Script returned: Major Lazer ft. Travis Scott, Camila Cabello & Quavo - Know no better (File=\\NAS\Audio\Music\Major Lazer - Know No Better (ft Travis Scott).wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18550.mp2).
25/07/2017 12:23:02: Processing Script returned: Cheryl - Call my name (File=\\NAS\Audio\Music\_IMPORTED_\SP18550.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Drake - Signs.wav).
25/07/2017 12:23:02: Processing Script returned: Drake - Signs (File=\\NAS\Audio\Music\Drake - Signs.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\DJ Khalid - Wild Thoughts ft Rihanna & Bryson Tiller.wav).
25/07/2017 12:23:02: Processing Script returned: DJ Khaled ft. Rihanna & Bryson Tiller - Wild thoughts (File=\\NAS\Audio\Music\DJ Khalid - Wild Thoughts ft Rihanna & Bryson Tiller.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17316.mp2).
25/07/2017 12:23:02: Processing Script returned: Union J - Beautiful life (File=\\NAS\Audio\Music\_IMPORTED_\SP17316.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:23:02: Processing Script returned: Miley Cyrus - Malibu (File=\\NAS\Audio\Music\Miley Cyrus - Malibu.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18647.mp2).
25/07/2017 12:23:02: Processing Script returned: JLS - Hottest girl in world (File=\\NAS\Audio\Music\_IMPORTED_\SP18647.mp2).
25/07/2017 12:23:02: Cancelled Script at Line 1 (LineTries=0, Tries=0/160): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: Cancelled Script at Line 1 (LineTries exceeded): 1 Random : A-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: GetNextTracks processed, 0 script result entries returned.
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Enrique Igesias ft Sean Paul & Matt Terry - SÚBEME LA RADIO.wav).
25/07/2017 12:23:02: Processing Script returned: Enrique Iglesias ft. Sean Paul & Matt Terry - Súbeme la radio (File=\\NAS\Audio\Music\Enrique Igesias ft Sean Paul & Matt Terry - SÚBEME LA RADIO.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Rita Ora - Your Song.wav).
25/07/2017 12:23:02: Processing Script returned: Rita Ora - Your song (File=\\NAS\Audio\Music\Rita Ora - Your Song.wav).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP17666.mp2).
25/07/2017 12:23:02: Processing Script returned: Mark Ronson ft. Bruno Mars - Uptown funk (File=\\NAS\Audio\Music\_IMPORTED_\SP17666.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Luis Fonsi & Daddy Yankee featuring Justin Bieber - Despacito.wav).
25/07/2017 12:23:02: Processing Script returned: Luis Fonsi & Daddy Yankee ft. Justin Bieber - Despacito (File=\\NAS\Audio\Music\Luis Fonsi & Daddy Yankee featuring Justin Bieber - Despacito.wav).
25/07/2017 12:23:02: Cancelled Script at Line 2 (LineTries=0, Tries=0/80): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: Cancelled Script at Line 2 (LineTries exceeded): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Liam Payne - Strip That Down ft Quavo.wav).
25/07/2017 12:23:02: Processing Script returned: Liam Payne ft Quavo - Strip that down (File=\\NAS\Audio\Music\Liam Payne - Strip That Down ft Quavo.wav).
25/07/2017 12:23:02: Processing Script-Line 2 (Retries=160): 1 Random : E-list (Filter=, Options=SuppressHistoryCheck, ForceLibraryHistoryCheck)a
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\_IMPORTED_\SP18776.mp2).
25/07/2017 12:23:02: Processing Script returned: Bastille - Pompei (File=\\NAS\Audio\Music\_IMPORTED_\SP18776.mp2).
25/07/2017 12:23:02: GetNextTracks processed, 1 script result entries returned (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:23:02: Processing Script returned: Little Mix ft. Stormzy - Power (File=\\NAS\Audio\Music\Little Mix - Power ft Stormzy.wav).
25/07/2017 12:23:03: Processing Script returned: Drake - Signs (File=\\NAS\Audio\Music\Drake - Signs.wav).
There are three possible scenarios:
a) some of your files in the media library are inaccessible
b) you have defined some global restrictions or script rules
c) all your tracks violate the Media Library History
I would at this point vote for option c) - as currently those violations are not logged.
But as you are using a NAS, it might also be sometimes a).
Note, that the media history check is performed based on the "Trackname" - two media entries are considered equal if their Tracknames are equal (if your tracks don't come with a trackname (e.g. Artist - Title), the uppercase filename is used).
I assume this is maybe the case here?!
This is basically the only explanation I would have when seeing the "Script-Line x skipped: no track found" message.
But can you maybe also post your .pfs script file here, to take a look at.
<script version="1">
<title>Test3</title>
<creator>ProppFrexx ONAIR</creator>
<date>2017-07-21T14:38:36+01:00</date>
<settings>
<mode>Sequential</mode>
<loopScriptLine>0</loopScriptLine>
<scriptOptions>248</scriptOptions>
<reloadMediaLibrary />
<asyncReloading>true</asyncReloading>
<initialTrack />
<archiveFilename />
<additionalSongHistoryFilename />
<maxHistory>0</maxHistory>
<historyUseExtendedCheck>true</historyUseExtendedCheck>
<historyForceTAGReading>true</historyForceTAGReading>
<historyKeepPersistent>true</historyKeepPersistent>
<historyUseStrictExtendedCheckArtist>false</historyUseStrictExtendedCheckArtist>
<historyUseStrictExtendedCheckAlbum>false</historyUseStrictExtendedCheckAlbum>
<historyUseStrictExtendedCheckTitle>false</historyUseStrictExtendedCheckTitle>
<historyArtistCrossCheck>0</historyArtistCrossCheck>
<historyAlbumCount>10</historyAlbumCount>
<historyAlbumMinutes>0</historyAlbumMinutes>
<historyArtistCount>10</historyArtistCount>
<historyArtistMinutes>0</historyArtistMinutes>
<historyTitleCount>5</historyTitleCount>
<historyTitleMinutes>0</historyTitleMinutes>
<clearHistoryAtReload>true</clearHistoryAtReload>
<jingleMediaLibrary />
<jingleFrequencyFrom>0</jingleFrequencyFrom>
<jingleFrequencyTo>0</jingleFrequencyTo>
<jingleMode>Random</jingleMode>
<jingleCount>1</jingleCount>
<advertMediaLibrary />
<advertFrequencyFrom>0</advertFrequencyFrom>
<advertFrequencyTo>0</advertFrequencyTo>
<advertMode>Sequential</advertMode>
<advertCount>1</advertCount>
</settings>
<scriptLines>
<line>
<mode>Random</mode>
<entry>A-list</entry>
<count>1</count>
<options>9</options>
</line>
<line>
<mode>Random</mode>
<entry>E-list</entry>
<count>1</count>
</line>
</scriptLines>
<fixTimeElements />
<scriptRules />
</script>
b) I have SuppressGlobalRestrictions and SuppressTrackRestrictions in the script. The issue also does not happen when the library history is set to 0.
c) All tracks have an artist and title set. While there may be some tracks with the same artist, there is none that have the exact same Artist - Title combo.
And you are sure you are using the 4.0.3.54 or higher?
Since with all what you are saying, all sounds totally standard and I am not able to reproduce that here.
So yes, please try 2 local media libs...
Else we might do a TeamViewer sesison tomorrow...
