FADEOUT DB column not read?
I have a DB view with a FADEOUT column but when this is loaded in ProppFrexx, the FadeOut cue point is missing. If I rename the exact same column to another cue point such as FULLLEVEL or OUTRO then it works fine. Is there something different about FADEOUT?
(This is a DB media library - I haven't tried a metadata database)
Re: FADEOUT DB column not read?
What (type of) database are you using and what exact value does your FADEOUT column contain and what column type are you using - and who populated this database initially (i.e. is this from a migration, e.g. from Jazzler or any other system.
And are you also using values for DURATION and/or CUEOUT - if yes, what values are used for these values.
(there are various internal checks made to ensure correct values; e.g. FADEOUT should not be greater than CUEOUT or the DURATION)
Maybe a complete layout of your database table would be helpful (incl. a few example rows).
May I ask, why you are using a database based media lib (which is essentially only supported for migrating from another system
I.e. make sure the DURATION value is present. Its value depends on the columns type:
- long, int : given in milliseconds
- double, float: given in seconds incl. fractions
- timespan, datetime: given directly resp. as the time of the day
Yes, it's a migration from an older system but the cue points were all checked and adjusted since. The cue points are stored as a double type. It is a MariaDB 10 (MySQL compatible) database.
Out of the ProppFrexx columns, I am using: TITLE, ARTIST, LOCATION, CUEIN, RAMP, OUTRO, NEXT, FADEOUT, CUEOUT, INITIALGAIN, GROUPING
The actual table contains more data, but they are not used by ProppFrexx.
Note that the other cue points I am using do work fine, such as OUTRO and NEXT.
Example row:
FULLLEVEL and RAMP2 also work but not FADEOUT.
There was a few initial reasons on using a DB media library:
Example row:
CUEIN | RAMP | OUTRO | NEXT | FADEOUT | CUEOUT
0.04 | NULL | 208.77832199546486 | 208.77832199546486 | 208.77832199546486 | 211.5872335600907
- Indeed the migration from an older system was easier.
- We are using data that is not supported by any playlist format I'm aware of (e.g. sort artist). ID3v2.4 would cover that though (TSOP), so only a folder-based media library is an alternative.
- The audio files did not migrate with a directory structure. The library separation was stored as data in the database. This could be migrated via a script however.
As noted above: Does you table/view also contain a DURATION column as explained above.
If not, this might be the reason.
No it does not have a DURATION - though the other cue points worked without it.
I see I missed mapping the DURATION column in the DB view so I will try it out.
The DURATION column is now properly mapped, and the FadeOut is now read. Thanks.
I assumed CUEOUT was sufficient, so that's the mistake I made.
Perfect!
