Broadcasting an external stream
WimHP
Post by WimHP »
Due to an event i want to broadcast an external stream for 2,5 days. What is the best way to do that in ProppFrexx?
All the other programs are skiped in the 2,5 days.
Wim
Hollands Palet
Re: Broadcasting an external stream
Create a mixer input channel and connect our external audio signal to the related line-in of your soundcard which you are using with the related mixer input channel.
Than use this mixer input channel as your source for streaming.
WimHP
Post by WimHP »
Thanks for the answer. But i think it will not work in my situation. Because i am using ProppFrexx on a VPS and the PC is not physical present.
Wim
WimHP
Post by WimHP »
I got a stream for 2,5 days and i want to broadcast it on my channel. Can i make a playlist with the stream or is there a better way?
Wim
Yes. Or You can also use a script with a single LoadTrack script-line and specify the URL as its entry.
Then I do not understand your initial question?!
How did believe can you stream an external event? If it is delivered digitally as a URL-stream, you can of course simply play this event stream in your ProppFrexx system. But if it is a live event, you would of course need a physical audio cable to your line input?!
