Remote voicetracking
One more question about voicetrakking. I live in brabant and a friend of mine in alkmaar. Now he wants to make a home radio program for me so I can play it with me. Does this happen with remote voice tracing or does not. And if that's the case then we need both the enterprise version.
Re: Remote voicetracking
Yes, that is the typical Remote Voice Tracking situation.
Your 'brabant' PF instance in this case acts as the 'server' part, and your friend is accessing that server from 'alkmaar' as a 'client'.
Thus, your server must use the Enterprise-Edition; and your friend's client might use even the Basic-Edition (even though I recommend the Premium, as that comes with the Segue-Editor).
Thank you for answering, so if I understand correctly, I can install my computer where ProfessionalEdition (Non-Commercial) is installed with my friend, so I only have to buy the enterprise for my home. And then he can do remote voice tracking to my server from enterprise version.
Yes, exactly.
Finally, I can get multiple licenses on my name
Can I also test with an enterprise demo version
Enterprise or Demo?
But yes, you can also test RVT with the Demo version.
Oke thanks, now i will test. Local can i connect white another pc white demo proppfrexx. Extern can i not connect. I have Port 9042 forward on te router.
Then you did either not correctly opened you port/forwarding or your IP is not reachable.
I cannot fully help with this, maybe you need to ask a network admin.
But be ensured, that it is working for a lot of users.
