What is this?
What is this?
I expect i can only do wrong things?
This is what i see.
EDIT:
30-10-2017 13:42:57 [v4.0.3.78]:********** Error/Exception Information **********
Error Message: Onvoldoende schijfruimte beschikbaar.
Error Type: System.IO.IOException
Error Source: mscorlib.Void WinIOError(Int32, System.String)
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.WriteCore(Byte[] buffer, Int32 offset, Int32 count)
at ProppFrexx.ProfileConfig.SetValue(String pSection, String pEntry, Object pValue)
at eF.f6.S3CD(Form , String )
at ProppFrexx.ScriptLibraryConfigDialog.OnClosing(CancelEventArgs e)
at System.Windows.Forms.Form.CheckCloseDialog(Boolean closingOnly)
********** End **********
This is what i see.
EDIT:
Re: What is this?
sorry wrong txt, other problem.radio42 wrote: ↑30 Oct 2017 14:00 Pretty much like the error message suggests: there is not enough space available.
This means: the file in the above dialog also got corrupted (in this case the song history).
You can check, if there is a .bak file for the given file available and restore that.
So I assume you are running out on disk space; please check your hard disk (on which you are saving your script libraries).
Re: What is this?
Thats it, thxs Bernd
Now yhe GPIO, normally it opens, now it doesn't, How to tackle that?
EDIT:
EDIT:
Re: What is this?
Then please try to open it manually (ProppFrexx GPIOClient.exe), maybe it also fails because of corrupt config files.
If that is the case, you might need to delete all corrupt config files (due to your hard disk running out of space) and then probably delete all your config files.
Note, that all config files are store in your ProppFrexx AppDataUser folder.
So at best you restore a backup of these files...else delete all and start from scratch...
Re: What is this?
It doesn't go well, now ProppFrexx won't accept the password anymore. Man is this a real puzzle. Is there a way to reset the admin password?
Re: What is this?
Maybe is is already reset?!
The default Password is: ProppFrexx
Have you tried that?
As said maybe restoring a backup helps?
Re: What is this?
Re: What is this?
?? NO, I guess you are now running into tons of side effects caused by your 'out of disk space' issue !
Please try to hold down the CTRL and the ALT key (together) while pressing the Program Scheduler ribbon button.
This should release the 'InUse' lock file.
Else go to the folder where you have specified your program scheduler calendar file to reside and delete the related ".~lock" file manually.
Re: What is this?
Hi Bernd, everything seems to work with exception of one thing. The admin password. One of the guys does not know the new password anymore. So we can only work in the standard users modus. Can you please help?
EDIT: It's FIXED!!
EDIT: It's FIXED!!
