delete scripts
Michel67
delete scripts
Post by Michel67 »
script are not running but i can not delete these scripts?
Re: delete scripts
You have probably NOT added this script (manually) here, but instead specified a 'Auto. Script Path' in the general settings, section 'Scripts/Scheduler' (see below for details). Automatically added scripts cannot be removed manually.
Please click on the '?' icon at the top right of the Options and Settings dialog to get detailed help about each option, like here:
Automatic Script Library Path:
Script files (.pfs) within this directory are automatically loaded as individual script libraries. If you leave this entry empty (which is the default and recommended) you might manage your script libraries manually by using the „Additional Script Libraries...“ button.
Michel67
Re: delete scripts
Post by Michel67 »
now discovered what I did wrong. nice someone who is so quick to answer questions, thanks again
