Set up marian trace pro
Kekke
Post by Kekke »
Is there anyone who use this card with Proppfrexx?
I want to use 3 players.
Thanks!
Re: Set up marian trace pro
I am not using that card. But...
What is your issue with that card?
Kekke
Post by Kekke »
This card has one analoog in / output with xlr.
Is this possible to work with Proppfrexx en use
three or two players?
How do i setup?
Sure, you can still route all DJ Players to the same mixer output channel.
You might also create 3 virtual mixer channels (using the NONE driver) and then output each of them to a 4th mixer channel which uses the physical output of your sound card.
If the card has no other output you might not really use any additional PFL channel with it - maybe you have another sound card available?
Kekke
Post by Kekke »
Thanks for the fast reply!
It works!
For the PFL i use a Behringer usb Soundcard.
Thanks.
