Shortcuts
Shortcuts
Browsing through the manual appendix i've expirienced a lot of shortcuts. Unfortunatly there are missing some of them.
PFL modus - ACDP, is it possibe to create that?
PLayout modus: Selection>downmix>save as....MP3?
RVT modus: Att volume, Pre listen, reset, Next playlist track.
Just some of 'm.
Can you help me out ot am i overlooking something?
Will
Just some of 'm.
Will
Re: Shortcuts
I am not sure, if shortcuts can be created for every function available in ProppFrexx - sometimes you simply need to use the mouse resp. use multiple key-clicks to get there.
However, you HotKey question has already been answered here (especially for The RVT modus), where several control-commands are available, which allow you to define your own hot-key mapping:
viewtopic.php?f=5&t=2168&p=10887
