Plugin Silence Detection Notification
Ahmed Saied
Post by Ahmed Saied »
Hi ,
I need plugin to make message and send to me from the server of online streaming of our radio through The SHOUTcast Server to detect the silence or failure in streaming output , sending me message through an email to handle all events and fails .
Thanks for caring .
Happy New Year 2019.
Re: Plugin Silence Detection Notification
Do you need a Shoutcast Server Plugin?
If yes, I cannot help here.
But note, that each mixer channel has a silence detection build in. You can use the mixers InSilence resp. OnNoise event to trigger any control-command, eg. to send out an email.
Is that what you are looking for?
If yes, ...To define/use them make sure you checked the ‘Enable Silence Detection’ option for the respective mixer channel (in its configuration dialog).
To use the events, go to the mixer control-command events, i.e. make a right-click onto the mixer-channel name and then select ‘Edit Control Command Events…
