Saving
westendradio
Saving
Post by westendradio »
Dear forum members, there is the possibility to save the media libarri, cartwall, playlists scripts and schedulle and overlay schedulle in proppfrexx and then restore them after a new installation of windows.
Re: Saving
What about the 'Backup and Restore' function - see the 'Tools' tab (note, that the backup would not copy your audio files).
This method only works in case you use the same drives and drive letters.
Else you can also make a copy of the resp. files and folders and restore them after.
This link will help in that case: viewtopic.php?f=9&t=140
