Export/import mixer settings
mixmog
Post by mixmog »
Is it possible to export the mixer/sound card settings from one instance of PF and import them into another?
I am looking to set up an identical instance to act as a fail-over and would rather not re-create a complete mixer set-up manually.
Thanks,
Dan
Re: Export/import mixer settings
No, as this doesn’t really make sense, as each soundcard or device is using different IDs on different PCs even if it is the same card.
But you can copy the file called „Default.mixer“ from your AppUserData folder and try, if it works by chance.
mixmog
Post by mixmog »
Just to clarify - it's the mixer settings and routing that I'm ideally wanting to copy: for example channels, channel headings, bus routing - that kind of thing
Yes, all except the routing is in that file.
The routing is stored in the „ProppFrexx ONAIR. config“ file.
mixmog
Post by mixmog »
Great, thank you!
