CAn't create script
SiriusRadio
CAn't create script
Post by SiriusRadio » 22 Nov 2019 11:47
Hi Bernd.
I can't create a script.
I shows:
22-11-2019 11:43:39: System.NullReferenceException
Object reference not set to an instance of an object.
at qr.DW.SpV7(Object , FirstChanceExceptionEventArgs )
at ProppFrexx.ScriptLibrary.GetNextTracks(Object prog, DateTime lastScheduleTime, DateTime nextScheduleTime, Int32 scriptLine)
at ProppFrexx.ScriptTester.Mpy.XImv()
22-11-2019 11:43:39: Script Test Exception : Object reference not set to an instance of an object.
22-11-2019 11:43:39: DispatchCommand: EXEC_SEND_OSC /home/timecode|s:B: Pos 0:15.3 RemainF 4:45.3
22-11-2019 11:43:39: DispatchCommand Reply: OK
22-11-2019 11:43:39: DispatchCommand: EXEC_SEND_OSC /home/timecode|s:B: Pos 0:15.6 RemainF 4:45.1
What can i do?
Keep it simple, please :)?
Re: CAn't create script
Post by radio42 » 22 Nov 2019 11:51
Please send me your script file (the related .pfs file).
Could it be, that you have not defined any real script-line in it to schedule tracks from a media lib?
SiriusRadio
Post by SiriusRadio » 22 Nov 2019 12:33
radio42 wrote:
22 Nov 2019 11:51
Unable to do so, Looked into the files, even when the script tells me it is saved in the script folder, nothing there -).
Post by radio42 » 22 Nov 2019 12:52
Maybe that is your issue, that you don’t have write access to that folder?
Are other scripts working?
Have you tried a different folder?
Is this. Local or networked folder?
Bumperke
Post by Bumperke » 22 Nov 2019 13:37
radio42 wrote:
22 Nov 2019 12:52
I can be. All other scripts run. Its local so i tried another folder. Works.
Post by radio42 » 22 Nov 2019 13:43
I am glad, that the issue is solved.
But you should investigate, what was blocking on that previous folder you tried?! - either an access right issue or check your hard disk for errors...
SiriusRadio
Post by SiriusRadio » 22 Nov 2019 15:10
radio42 wrote:
22 Nov 2019 13:43
Dont think so Bernd, All other scripts also run and there saved in the same folder, must be a rights issue i guess,...
Was never an issue as of today, strange phenomon.
Who is online
Users browsing this forum: No registered users and 10 guests
