MCU lcd
djbony
MCU lcd
Post by djbony »
I bought a Behringer X-Touch and set it up with PF. Everything works, but I can't set the texts on the LCD. The MCU lcd command does nothing. Thank you for your help...
Re: MCU lcd
I guess I am not the right one to ask, as I don’t know that device nor it’s exact interface capabilities.
If everything works fine, but just the LCD update, it might be a limit of the Behringer?
djbony
Re: MCU lcd
Post by djbony »
X-touch has 8 displays. One for each fader. The MCU command does not tell which display to send data to. That's why it probably doesn't work ...
Re: MCU lcd
Maybe you should ask this to the Behringer support...?
djbony
Re: MCU lcd
Post by djbony »
I wrote them on Friday. No answer yet.
djbony
Re: MCU lcd
Post by djbony »
Here is answer from Behringer...
Dear Petr,
Thank you for your contact.
Please be aware that for the functionally requirements that you stated you will need a controller that has MIDI CC functionality and the X-TOUCH was not designed as a MIDI CC controller.
The X-TOUCH was designed to interact specifically with MIDI messages to and from DAW and not TO transmit MIDI messages that are capable of transmitting a range of values, usually allows 128 different continuous controllers available for each MIDI channel.
The X-TOUCH COMPACT or X-TOUCH MINI are designed with MIDI CC functionality.
Re: MCU lcd
I don’t fully understand that answer, but it sounds the x-touch doesn’t fully support MIDI messages?!
djbony
Re: MCU lcd
Post by djbony »
I've already figured it out. XTouch has another LCD control header: 00 00 66 14. Could you add an MCU command - like lcdxtouch? This SysEx works: 0xF0 0x00 0x00 0x66 0x14 0x12 0x00 "*[STRING:{${outputmixer1name}}:{rpad}:{6}] " "*[STRING:{${outputmixer2name}}:{rpad}:{6}] " "*[STRING:{${outputmixer3name}}:{rpad}:{6}] " "*[STRING:{${outputmixer4name}}:{rpad}:{6}] " " " "*[STRING:{${inputmixer4name}}:{rpad}:{6}] " "*[STRING:{${inputmixer1name}}:{rpad}:{6}] " "*[STRING:{${inputmixer2name}}:{rpad}:{6}] " 0xF7
Re: MCU lcd
Hmm, I don’t really like to add hardware specific stuff, which is a non-standard.
If your sysex is currently working why adding something on top of it?
djbony
Re: MCU lcd
Post by djbony »
I guess you're right. But could you advise me? What function to use to display GAIN correctly on LCD? It gives me values ​​from 0-127 instead of -15 to +15. Thank you.
