Jingle Problem
westendradio
Jingle Problem
Post by westendradio »
Dear forum members, what strikes me is that pf regularly plays jingles from a different folder than is set in the playlist script. How can I solve this.
Re: Jingle Problem
This sounds impossible!
I assume, that probably some script-lines might be skipped due to a configuration/history issue.
A) what version and edition do you use
B) please post your related script file (.pfs)
C) please run the ‚Test...‘ function of the script and indicate which script-line causes the trouble.
And send me a copy of the full Test-Output.
Thanks
westendradio
Re: Jingle Problem
Sorry for the late response, I have something overlooked. The problem was that I had not changed a playlist templates. Problem solved.
Re: Jingle Problem
I am glad, that you found the issue.
