OSC Problem
Jo Discoboom
OSC Problem
Post by Jo Discoboom »
I meet a problem with TouchOSC, the "Main" and "Cartwall" does not work, there is only the "Mixer" which works.
In the "monitor" window of ProppFrexx, the commands work, I think of a problem in "Events / Commands"?
thank you in advance
Thanks
Text translated by Google Translate.
Re: OSC Problem
I cannot see Ie reproduce any issue with oSC here!
Have you used the TouchOSC demo as provided or your own mapping?
Maybe you did some mistake with the event mapping or control-commands.
Use the ‘Monitor...’ function to track the issue.
Jo Discoboom
Re: OSC Problem
I used the zip "ProppFrexx_ONAIR_TouchOSCiPad.zip" > post : viewtopic.php?t=23
Re: OSC Problem
And what exactly is not working? I.e. what error messages do you get?
You might need to check this via the 'Monitor...' function.
However, the TouchOSC zip file is pretty old and was never really adjusted. E.g. in the meantime some control-commands might have been changed.
I.e. any ...CARDWALL... or ...CARD... control-command was correctly renamed to ...CARTWALL... resp. ...CART... (D -> T replacement)
(E.g. you need to rename the mapping from CW1/2_PLAY_CARD to CW1/2_PLAY_CART)
You might need to adjust those commands in the OSC setup yourself ;-)
(this is a known bug unfortunately, as reported here: viewtopic.php?f=9&t=23&start=30#p11200)
Jo Discoboom
Re: OSC Problem
I have no error message.
In "Main", the ipad does not synchronize with PF, no button works and in "Cartwall" the names of the jingles appears but when I press them, the sounds do not start, I only have the PFL which works .
When I go into the monitor function and I press the ipad, the commands appear.
Re: OSC Problem
Yes, but probably the command: CW2_PLAY_CARD - which needs to be renamed to CW2_PLAY_CART.
Jo Discoboom
Re: OSC Problem
Where can I find the orders to modify?
Directly in PF or with the editor?
I have already changed the names "cardwall 1/2" to "cartwall 1/2" in TouchOSC Editor
Jo Discoboom
Re: OSC Problem
it works, I modify the .osc file with notepad
