Track error on dj instream
Erris
Post by Erris »
We are using in streams for our dj's but if a Dj does not run music or noice ProppFrexx will shutdown the stream in the playlist and play the next number.
My question is, has ProppFrexx the abillity to keep the in stream open.
Erris - Radio Midden Nederland
ProppFrexx ONAIR 4.4.2.0
Running on a
Server 2022 standard
Processor: Intel Xeon Processor (Skylake, IBRS) 2.10GHz
Mem: 12 GB
Re: Track error on dj instream
What is an 'in stream' ?
Do you mean a normal stream via the streaming server to e.g. SHOUTcast or ICEcast?
If yes, it is a function of SHOUTcast/ICEcast to cut off the source, if there is only silence streamed to it.
You might need to configure this on the SHOUTcast/ICEcast side... this has unfortunately nothing to do with ProppFrexx and can not be controlled from my side.
Erris
Post by Erris »
Okay i'm going to find that out befor i report back again.
Running on a
Mem: 12 GB
