Startup
segers andre
Startup
Post by segers andre »
I am a new user of Proppfrexx. To date, this software is phenomenal. Can someone help me with the following problem?
How can I make proppfrexx start up via my usb license, without having to manually enter the validation code every time.
Must be possible after a possible power failure. Thanks
Re: Startup
Take a look to the user manual there you’ll find a “-usbreg” command-line Parameter which you can use when starting ProppFrexx to enforce using the USB registration mode.
segers andre
Re: Startup
Thanks, Bernd for the tip. It works
gerritk
Re: Startup
Post by gerritk »
@segers andre How does this work?
Run command in START menu C:\Program Files\radio42\ProppFrexx ONAIR\ProppFrexx ONAIR.exe -usbreg works fine
But how to make an shortcut? When I put it in CMD it doesn't work. Even by START command.
Re: Startup
A shortcut on the desktop was probably already created with the installation.
Make a right click, select Properties and edit the start command and simply add -usbreg at the end.
gerritk
Re: Startup
Post by gerritk »
This gives a fault Image
Run as admin
Re: Startup
Move the -usbreg outside the quotes!
Only the path and filename needs them.
gerritk
Re: Startup
Post by gerritk »
It works!
Thx ;)
