Play line in feed in Overlay
polp6880
Post by polp6880 »
I currently have an overlay set up like this: https://share.getcloudapp.com/v1uxlP4X
Item #2 in the list is my line in feed, which I know it works as I'm using that line in a Program already, however, it seems that when the Overlay is played, the line in feed command is skipped completely and only item #1 and item #3 are added.
Is it not possible to play a line in feed in an Overlay?
If it's required, these are the options I set on the Overlay itself: https://share.getcloudapp.com/WnurdmyJ
Re: Play line in feed in Overlay
No, a LineIn Feed can not be played via a script within an overlay (like it can be via a program scheduler entry). The reason is quite simple. For overlays the entries are played as one embedded container, which is of course not possible for a live LineIn Feed.
However, you can create an individual overlay scheduler entry and set its 'Type' to 'Input'. This way you can also play a LineIn Feed as an overlay!
