screen view
D3R3K
screen view
Post by D3R3K »
Bernd, on the main player which shows the songs, commercials, and other things only allows me to see 7 items at a time on a scroll. Is there a command that will let me see the whole our on a scroll? Thanks
Re: screen view
Sorry, I am not sure what element you mean?!
Each window however is fully sizable.
In addition the playlist for example is fully customizable in its layout, columns, rows and even the font.
If that is not sufficient, ProppFrexx supports any monitor size and even a multi-monitor setup.
So can you post a screenshot what exactly you mean?!
D3R3K
Re: screen view
Post by D3R3K »
ok how do you resize?
Re: screen view
Resize what!!
I asked you to specify the element, but you didn’t answer.
