ProppFrexx tagger bulk edit
franksiegers
Post by franksiegers »
Is there a way to set the track type (like Bed, Sweeper) for multiple tracks at once?
Also, could this perhaps be done with MP3 tag since I use this anyway or is Type a PFOA-specific tag that other software doesn't understand?
Re: ProppFrexx tagger bulk edit
Yes.
In the playlist go to the Meta Data ribbon tab and enable the e.
Than select the related rows in the playlist and than enter the cell which you want to change and type the new value. Press the enter key and all selected row are changed at once for that value. Exception is the
Title column, which can only be changed by its own.
Once done with the editing disable the ‘Direct TAG Editing’ button. And all changes are saved.
franksiegers
But Track Type is not a selectable column here is it?
Oh, it is. Just right click on that column showing the icon and a popup appears, where you can select the Type and change it also for all selected tracks.
