Encoder settings
Encoder settings
Hello Bernd I can create different server profiles.
I now have several Icecasts and a Shoutcast, the Icecasts have the encoder setting mp3 128 kbits 44100
the shoutcast mp3 320 kbits 44100
, can I use different encoder settings or only one is possible for all streams
Re: Encoder settings
Yes, you can use as many encoder profiles as you like.
Just just assign one per streaming server and define the format, e.g. MP3. That gives you any flexibility.
You can even define the network interface to use (in case you have multiple).
Thank you for the information.
Hello, I have another question about servers.
I know there is the Start All Server function. But since I have a radio that only has my show in the program on Wednesdays. can I start selected server profiles with the server start command?
Then you need to start them individually- there is a related command for that as well.
