Parallel program
ErikW
Parallel program
Post by ErikW »
Since version 3.0.12.6 I regularly have a problem with the programming.
This comes from the log files of the scheduler
15/10/2013 10:58:57: WARNING: Parallel-Program 'namiddag nonstop-nonstop ma-di-do-vr@2013-10-15T11:00:00' not started (Program 'namiddag nonstop-nonstop ma-di-do-vr@2013-10-15T11:00:00' was already started).
15/10/2013 10:58:57: WARNING: Parallel-Program 'Muziektrein-Muziektrein dinsdag@2013-10-15T11:00:00' not started (Program 'namiddag nonstop-nonstop ma-di-do-vr@2013-10-15T11:00:00' was already started).
First program is between 11u00 and 12u00, second between 12u00 and 18u00.
Is there a configuration change between previous and current version?
Re: Parallel program
No, nothing has been changed regarding the scheduler in the last versions.
But looking at the log entries, it looks like you indeed have defined both programs to start at 11:00:00 ?!
The name is before the '@' sign and after you'll have the effective start date/time - and as you can see, both are supposed to start at 11:00:00
ErikW
Post by ErikW »
Strange, this is from the calendar:
<Appointment Type="1" Start="10/14/2013 11:00:00" End="10/14/2013 12:00:00" Label="2" Location="Muziektrein maandag" Subject="Muziektrein " MaxDelay="120" MixTime="1000" Overlay="0" ReloadScript="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="">
<RecurrenceInfo Start="10/14/2013 11:00:00" End="12/16/2013 11:00:00" WeekDays="2" Id="9f479a99-7935-4af7-9a70-e008f3033bb2" OccurrenceCount="10" Type="1" />
<Reminders>
<Reminder AlertTime="10/21/2013 10:58:42" TimeBeforeStart="00:01:18" />
</Reminders>
</Appointment>
<Appointment Type="1" Start="10/14/2013 12:00:05" End="10/14/2013 18:00:00" Label="1" Location="nonstop ma-di-do-vr" Subject="namiddag nonstop" MaxDelay="120" MixTime="1000" Overlay="0" ReloadScript="False" AllowOverlayCancel="False" AllowOverlayDelay="False" OverlayPauseSuspended="False" AllowStartEarly="False" BridgeTrack="">
<RecurrenceInfo Start="10/14/2013 12:00:05" End="10/29/2013 12:00:05" WeekDays="54" Id="7a65686d-cc64-4521-b903-4fa76527f896" OccurrenceCount="10" Type="1" />
<Reminders>
<Reminder AlertTime="10/17/2013 10:58:42" TimeBeforeStart="00:01:18" />
Maybe you have defined some exceptions to your base recurrence?
I don't know without seeing the full calendar with all it's entries...
ErikW
Post by ErikW »
@Bernd: see PM
Please also try the latest v3.0.12.7 - which should fix some of your issues!
