Showing Set Cue Point et. In PFL Player
RedPanda
Post by RedPanda »
So I went through an audio folder and using the PFL player set all the cue points on the audio files and saved meta data tag.
Why when I open these files again in the PFL player does it not show the saved cue point etc. ??
The meta data is saved because when I put them on the playlist, the players show the correct points.
But why when I want to double check my saved cue points, the PFL player doesn't show them when opening them from the explorer?
Re: Showing Set Cue Point et. In PFL Player
Yes, that was indeed a bug.
A new v3.0.12.9 is now available, which fixes that!
RedPanda
Post by RedPanda »
Thanx Bernd!
