Unhanded Exception!! ProppFrexx won't open!
louis
Post by louis »
10/5/2014 7:16:53 AM [v3.0.14.16]:********** Error/Exception Information **********
Error Message: Cannot access a disposed object.
Object name: 'XtraScrollableControl'.
Error Type: System.ObjectDisposedException
Error Source: System.Windows.Forms.Void CreateHandle()
at System.Windows.Forms.Control.CreateHandle()
at System.Windows.Forms.Control.get_Handle()
at System.Windows.Forms.Control.get_ShowKeyboardCues()
at DevExpress.XtraEditors.LabelControl.get_HotkeyPrefixState()
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcSimpleTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode, Int32 predWidth, Int32 predHeight)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(String Text, Boolean useHotkeyPrefix, LabelAutoSizeMode mode)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextSize(Boolean useHotkeyPrefix)
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcTextPoints()
at DevExpress.XtraEditors.ViewInfo.LabelControlViewInfo.CalcContentRect(Rectangle bounds)
at DevExpress.XtraEditors.LabelControl.LayoutChanged(Boolean isVisualUpdate)
at DevExpress.XtraEditors.LabelControl.LayoutChanged()
at DevExpress.XtraEditors.LabelControl.OnHandleCreated(EventArgs e)
at System.Windows.Forms.Control.WmCreate(Message& m)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
********** End **********
What do I do?
louis
Re: Unhanded Exception!! ProppFrexx won't open!
Post by louis »
I deleted the layout file for my main user, restarted propp frexx, then restored the layout from another user. Seems to be working again. Not sure what happened there. Insight?
Looks like some bug in the UI lib I am using. But really hard to say from the error details, as it just indicates that lib.
But you did the right thing to recover it.
I'll post the error to the UI lib vendor to see, if they go any clue...
