Update error!
PD1LG
Update error!
Post by PD1LG »
When updating, I get the following error message.
Backup not successfull!
Update not possible.
How do I fix this?
Re: Update error!
The Backup copies the content of the current installation folder to a sub-folder called 'Previous Version'.
If this is not possible the mentioned error is happening.
May be because a file within the Previous Version folder is in use/opened. Have you may be started ProppFrexx from within that folder?
Else you might try move that folder away to another location using the windows explorer to what error you get there. Do not copy but move the folder!
