New Forum Theme
This forum is unmoderated!
RedPanda
New Forum Theme
Post by RedPanda »
Now that you updated the forum software it would be nice to put a theme on it rather than the ugly default blue. Maybe something that matches your website colors.
Re: New Forum Theme
There are 3 themes available you can choose from in you user settings.
Others might be added later. But I do for sure does not spend days and days designing an own theme. Guess it's more useful to invest that time in other features...
Re: New Forum Theme
Note, that you can change your theme in the "User Control Panel" of the forum (see your profile name at the top right) - then go to "Board Preferences" and change your theme as needed /wanted ;-)
RedPanda
Re: New Forum Theme
Post by RedPanda »
Ok, Thanks. Just thought the default color clashes with your site. WIll look at the installed themes.
RedPanda
Re: New Forum Theme
Post by RedPanda »
OK I checked the other themes. I think you should set the default theme to the one called "SE Square Left" This is the color that matches your website, and if people are not signed in should see, otherwise it defaults back to blue if you are not signed in. Just a suggestion from someone who likes consistency. :)
Re: New Forum Theme
The new "we_universal" theme is best matching the web site I guess.
This is now the new default theme ;-)
RedPanda
Re: New Forum Theme
Post by RedPanda »
Ah yes, that is correct and looks best!
