Send tcp-command
This forum is unmoderated!
sbourghardt
Send tcp-command
Post by sbourghardt »
In september we will start broadcasting a live morning show toghether with anothe station using Station Playlist. They will listen to our broadcast via a stream. But every 25 minutes we will have to start their commersial block via a TCP-command.
I wonder if it's possible and how I set up a TCP-command that will send the command "Play" via IP.
Re: Send tcp-command
You can use the control-command EXEC_SEND_TCP, e.g.:
EXEC_SEND_TCP 192.168.0.1:8042|Play
sbourghardt
Thanks
