On air time windows not visible
This forum is unmoderated!
mikedude
Post by mikedude » 08 Oct 2017 17:22
I dragged the "onair time" window with my mouse and now it's gone.
When I click the View tab en the OnAir Time icon it's not coming back.
Think it's hidden somewhere... but where?
Online
Re: On air time windows not visible
Post by radio42 » 08 Oct 2017 17:47
I don't know ;-)
If you go to the 'Look and Feel' general settings, you can reset your layout.
To prevent this from happening again, you can even save your entire Workspace as a Default and then restore it at any time.
mikedude
Post by mikedude » 09 Oct 2017 20:15
Did that.
Some windows don't come back. Also played with Cartwall I window. Dragged with the windows and dropped it somewhere. Never comes back.
Online
Post by radio42 » 09 Oct 2017 20:18
What version are you using?
If nothing helps, please close PF, locate the file "ProppFrexx ONAIR.layout" (which is located in the ProppFrexx AppUserData folder) and delete this .layout file; and then restart PF.
mikedude
Post by mikedude » 09 Oct 2017 20:40
Latest version. Will try that.
thanks
mikedude
Post by mikedude » 09 Oct 2017 22:08
Should it be here: C:\Users\User\AppData\Roaming\radio42\ProppFrexx ONAIR ?
Online
Post by radio42 » 10 Oct 2017 01:24
Yes, but within the 4.0 sub-folder...
And what does latest version mean, a real version number would be more helpful ;-)
mikedude
Post by mikedude » 15 Oct 2017 19:41
I have 4.0.3.76 and the OnAir Time windows returned after deleting the file.
thanks!
Online
Post by radio42 » 15 Oct 2017 20:31
Jolly good.
Note, that there is also a new v4.0.3.78.
Who is online
Users browsing this forum: No registered users and 1 guest
