PF gives error after installing 4.0.4.7
mark62
Re: PF gives error after installing 4.0.4.7
Post by mark62 »
It works again, thanks for that, but the only strange thing that happened now is that I have the 32-bit version.
Also when I start up version 4.0.3.71 it is 32-bit.
How can I go back to 64?
regards Mark
I am already in talks with the developer of the audio lib; there is probably some issue with the AUDIOSES.DLL, which is a system file causeing the issue.
In the meantime you might safely use this file and replace the related "bass.dll" directly within your ProppFrexx Installation folder:
bass.zip
(239.51 KiB) Downloaded 446 times
In case you are using the 64-bit version, make sure to use the bass.dll from the x64 sub-folder!
You probably never installed the 64-bit version ;-)
You can however simply install the 64-bit version from here: http://www.proppfrexx.radio42.com/download.html
Probably you want to first deinstall the 32-bit version (as else you would keep both versions).
Note, that you won't loose any settings, as they are kept in the ProppFrexx AppUserData folder.
mark62
Post by mark62 »
Than I must be very confused. Must be my age :-)
Good to hear that my settings are saved.
