Exact Time Blocks
Contacto FM
Exact Time Blocks
Post by Contacto FM » 13 Jul 2018 16:30
Is it possible that the Musical Blocks are accurate?
For Example: That the Advertising Batch ends at the Point (00:00 Hours) to start the next Block
That within the Block already includes so much advertising
The Idea is that the entire Block. (Both music and Advertising) End the time at Punto
So that the Next Block enters Punctually
Re: Exact Time Blocks
Post by radio42 » 13 Jul 2018 16:33
Yes. Take a look to the Overlay Scheduler entry: there you'll fine the "EndsAt" start type.
Press '?' at the top right to get more info...
Contacto FM
Post by Contacto FM » 14 Jul 2018 02:30
Please Bernd, explain a little better ... Or tell me where I find more information ℹ
Post by radio42 » 14 Jul 2018 08:01
What is unclear?! And have you looked to the ‚?‘ help button.
The EndsAt Start Type does exactly what you described in your initial post. It ends the overlay at the given time exactly and thus calculates its effective start time dynamically. Ie. :
Effective start time = start time - overlay duration
Contacto FM
Post by Contacto FM » 14 Jul 2018 12:46
Excellent,.
Forgive my ignorance. One last query, In the Musicalizador I do not have to put anything specific so that the playlists can also be as accurate as possible?
Contacto FM
Post by Contacto FM » 14 Jul 2018 12:47
Excellent,.
Post by radio42 » 14 Jul 2018 20:31
No, but the program scheduler entry also has an option called TryEnsureExactLenghth, but this reflects the end time of the program and doesn’t take any dynamic EndsAt overlays into account.
So you don’t have to use that option in your case.
Contacto FM
Post by Contacto FM » 14 Jul 2018 20:38
Dear friend Bernd I want to tell you that after all the consultations, which of course you have answered without any problem ,. I have managed to make the ProppFrexx well configured ... I have a detailed view of your tutorials on YouTube, plus the advice you provide in this forum. In short .. Thank you very much ... May God continue to bless you and may he grow Radio42 (ProppFrexx) ... A big hug 🙌
Post by radio42 » 14 Jul 2018 21:00
Thx
Who is online
Users browsing this forum: No registered users and 27 guests
