ProppFrexx working with D&R
Bumperke
Post by Bumperke » 11 Oct 2018 16:18
Hi Bernd.
Can you help me me?
We want to purchose a new mixer, and that will the D&R AIRLAB or AXUM.
Are they also compatible with PF?
Including que, etc etc?
Will
Re: ProppFrexx working with D&R
Post by radio42 » 11 Oct 2018 18:05
As far as I know is the D&R AirLab using the exact same USB lib as the Airence - as such, yes, this mixer is compatible.
I am not sure about the AUXUM, as D&R planned to add Ember+ support to this mixer. If they completed this, than yes, else no. You need to contact D&R to request the Ember+ support status actually.
Bumperke
Post by Bumperke » 11 Oct 2018 18:31
radio42 wrote:
11 Oct 2018 18:05
You’re referring to the Airence, I’m the Airlab
https://www.d-r.nl/airlab.html
Will
Post by radio42 » 11 Oct 2018 21:22
Yes exactly, as said: the D&R AirLab is using the exact same USB lib as the Airence - thus we are compatible - as ProppFrexx supports the Airence USB lib - and as that USB lib is the exact same as the one used for the AirLab I also do support the AirLab.
This is even shown on the D&R web-site ;-)
Who is online
Users browsing this forum: No registered users and 8 guests
