Smooth track transition
Re: Smooth track transition
Post by radio42 » 08 Oct 2019 16:05
I need to take a look. I am currently on holiday, but will take a look next week, when I am back.
Post by radio42 » 10 Oct 2019 19:34
When you use the 'Save As...' function to save a playlist as a CSV format, you can define the fields yourself.
Just edit the file called "ProppFrexx.exportformats" (contained in the ProppFrexx installation folder) and add the needed field to the "Default CSV" section. You can use any existing track macro, e.g. add a new line using the ${tempostart} resp. ${tempoend} macro.
JWvanGulik
Post by JWvanGulik » 11 Oct 2019 16:52
Hi Bernd, I try to add these fields to the csv output in "Proppfrexxexportformats", but I cannot save the changes. Is this a read only file? Or in which program should I open this file (I used Wordpad)?
Post by radio42 » 11 Oct 2019 19:05
You just need to enable write access to that folder or edit it with Administrator rights.
JWvanGulik
Post by JWvanGulik » 12 Oct 2019 15:51
Administrator rights are not the problem. I need to be granted access by the "owner". I can send you a screenshot if required.
Post by radio42 » 12 Oct 2019 18:32
When you make a right click on the installation folder you can grant full access to all users - that should make the file editable.
You can use the user ‚Everyone‘ and add to the rights list and grand all rights to it.
JWvanGulik
Post by JWvanGulik » 12 Oct 2019 19:01
Yes, that's it.
Post by radio42 » 15 Oct 2019 12:58
A new v4.1.4.4.-update is available.
It adds a new Script-Option called "UseLocalScriptRuleChecks".
If enabled (per script) - the script-rules are evaluated inline per script-line (only for Random and Sequential modes as well as AutoJingles)!
Let me know, if this works for you.
JWvanGulik
Post by JWvanGulik » 15 Oct 2019 13:05
Thanks! I will let you know if it works.
JWvanGulik
Post by JWvanGulik » 16 Oct 2019 19:48
Hi Bernd, it works like a charm! This is the solution to my request, thanks for that.
I almost don't dare to ask, but do you see a way to not let the music tracks be selected based on their tempi, but only the automated jingle in between? This way only the jingles are selected based on their tempi (they don't have a history restriction). This could result in a more divers program.
-JW
Who is online
Users browsing this forum: No registered users and 3 guests
