Impossible de lancer le logiciel
Jo Discoboom
Post by Jo Discoboom » 17 Apr 2019 17:10
Bonjour, depuis la mis à jour de Lundi, ProppFrexx ne démarre plus, une erreur apparaît !
Voila le rapport :
17/04/2019 16:42:25 [v4.0.5.27]:********** Error/Exception Information **********
Error Message: The type initializer for 'Un4seen.Bass.Bass' threw an exception.
Error Type: System.TypeInitializationException
Error Source: Bass.Net.Int32 BASS_GetVersion()
Inner Exception: Tentative de chargement d’un programme de format incorrect. (Exception from HRESULT: 0x8007000B)
at Un4seen.Bass.Bass.BASS_GetVersion()
at eT.jt.SryV()
at ProppFrexx.ProppFrexx_ONAIR.PSMP(Object , EventArgs )
Error Message: Tentative de chargement d’un programme de format incorrect. (Exception from HRESULT: 0x8007000B)
Error Type: System.BadImageFormatException
Error Source: Bass.Net.Boolean BASS_SetConfig(Un4seen.Bass.BASSConfig, Int32)
at Un4seen.Bass.Bass.BASS_SetConfig(BASSConfig option, Int32 newvalue)
at Un4seen.Bass.Bass.QOS()
at Un4seen.Bass.Bass..cctor()
at ProppFrexx.ErrorDialog..ctor(Exception e, Boolean getFullInfo)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at DevExpress.XtraEditors.XtraForm.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc(Message& m)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at DevExpress.XtraEditors.XtraForm.SetVisibleCore(Boolean value)
at DevExpress.XtraBars.Ribbon.RibbonForm.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.Run(Form mainForm)
at YF.hY.Main(String[] args)
********** End **********
Merci de votre aide !
Re: Impossible de lancer le logiciel
Post by radio42 » 17 Apr 2019 17:16
What version are you using? The 32-bit or 64-bit version?
Are you may be using BASS somewhere else or is maybe another application using BASS somehow in a different context and places a file called BASS.dll into the Windows system folder?
I just tried the v4.0.5.27 here myself, but did not experience any issues.
Or did the update may be somehow failed?
If yes, please find below the latest 64bit version as a zip file to manually overwrite all your files in your ProppFrexx installation folder.
Make sure to first close all ProppFrexx applications!
http://www.proppfrexx.radio42.com/downl ... e40527.zip
Regards,
Bernd
Jo Discoboom
Post by Jo Discoboom » 17 Apr 2019 19:07
We are in 32-bit version because we have an old RME sound card.
It is possible that there was a bug during the update, otherwise, it is possible to return to the previous version?
Jo
(translated by google translate)
Jo Discoboom
Post by Jo Discoboom » 17 Apr 2019 19:33
I managed to restart ProppFrexx by restoring the Bass DLLs from the "previous version" folder in the main software folder.
Let's hope it works well.
Thank you anyway !
Jo
Post by radio42 » 17 Apr 2019 20:08
Ohh now I see it, yes, there was indeed a wrong bass.dll placed into the update zip by acident!
Here comes a new 32-bit version which corrects it:
http://www.proppfrexx.radio42.com/downl ... e40528.zip
Who is online
Users browsing this forum: No registered users and 4 guests
