Connection problem
Marco
Connection problem
Post by Marco » 22 Jul 2019 10:36
Good morning,
I updated windows 10 to version 1903. And Proppfrexx to 4.1.2.1
Now my connection with the shoutcast server fails. I disabled the firewall and that didn't help.
Has annyone the solution for this problem?
With kind regarts, Marco
Re: Connection problem
Post by radio42 » 22 Jul 2019 10:48
I think this must be local to maybe your Windows Update, as it is working here and also with other users without issues.
So I am sorry to not be of much help.
Marco
Post by Marco » 22 Jul 2019 11:15
Tank you. It is a local issue. But can not find te problem. Thanks for reacting.
Post by radio42 » 22 Jul 2019 11:51
Have made a reboot? Have you tried to disable also any AntiVirus software? Or even reinstalled ProppFrexx? Maybe that might solve the issue?
Marco
Post by Marco » 22 Jul 2019 12:52
I have rebooted several times. Ditn't work. No Antivirus installed.
Strange thing is that if switch to icecast instead of shoutcast de connection is made. And everyting works.
Mind you that i stream with shoutcast…
Marco
Post by Marco » 30 Jul 2019 18:50
Problem with connection mysteriously solved…
Stream is up and running. Everyting looks oke!
Who is online
Users browsing this forum: No registered users and 22 guests
