Retrieve mixer state
This forum is unmoderated!
mixmog
Post by mixmog » 09 Sep 2019 00:17
Hoping to be able to use a command or set of commands, to pull the mixer state (for example, all the input faders) of one instance of PF and apply it to another when the second instance starts. Is this possible?
Would be grateful for some guidance.
Re: Retrieve mixer state
Post by radio42 » 09 Sep 2019 12:32
There is currently no good way to achieve this - I am afraid.
Why is this needed, as normally each ProppFrexx instance should control its mixer state and volumes independently (i.e. they run on different hardware with a different setup and environment).
Who is online
Users browsing this forum: No registered users and 1 guest
