PF crash - Out of memory
fred48fm
Re: PF crash - Out of memory
Post by fred48fm »
Thank you for your quick response.
I monitored the values for few days, but nothing changed significantly, so I've considered it as solved...
I will follow it more longer.
The problem now is that considering the system is in live production, we cannot remove streamdeck component and homecast, so i'll keep an eye on that and, if the issue is time related, manage a weekly nigthly reboot.
As you say that can come from lots of other stuffs.
Thanks a lot for your help !
No News to this subject? Can I assume this solved and only be a temp issue?!
No feedback - as such, I assume, that the issue is solved.
fred48fm
Post by fred48fm »
Thank you for following the issue.
It seems finaly that it was a homecast related problem.
I replaced the Homecast by the classical Icecast server (still on the same computer running PF). And since then (3 weeks), no crash.
Best regards,
